Download: http://archive.info-mac.org/inet/html/w ... or-311.hqx
Web Page Creator 3.1.1
by Albright Software - June 25, 1998
Web Page Creator (WPC) 3.1.1 is an easy to use program for creating your
own simple web pages. If you want to create your own page on the web
without learning a speck of HTML, this is for you!
The minimum requirements of WPC are as follows...
Any Macintosh with a 68020 processor or higher, or a PowerPC processor
Mac OS 7.1 or later
768k of free RAM
This version has the following changes since 3.1...
-WPC no longer puts an annoying bracket character at the end of the
Content field when you save your page
-Now EVERY special character in the Content field gets translated to its
HTML equivalent, and the program now puts a for a paragraph break
(two returns) instead of two tags
-Banner feature removed temporarily
-Small cosmetic changes
-Some of the Balloon Help balloons have been updated
-The Save button now only is enabled after you've changed your page from
the last save
-Cut, Copy and Paste now work
