WebCalendarMaker
WebCalendarMaker
Download: http://archive.info-mac.org/inet/html/w ... -maker.hqx
WEB CALENDAR MAKER
"WCM" is a program designed to make it easy and quick to create calendars in
HTML format to be posted on web sites.
The program allows you to add and edit events and details about those
events. When ready, you simply hit an EXPORT button and the entire calendar,
including all event details and their files are exported. Pop-up windows and
links are created without the user needing to know javascript or advanced
HTML coding.
Then, just upload the CALENDAR folder to you web site.
A javascript is provided to allow you to make a link to the "Current Month"
calendar.
I wrote it because I could not find a web calendar program that did the
things I wanted. My goals were to create a program that...
1. is simple and easy to use
2. is usable by someone who does not understand advanced HTML
3. has a feature to allow advanced HTML users to edit the look and feel
of the calendars
4. offers pop-up-windows to see the details of an event
There are several programs out there that provide similar functionality to
"WCM". Most are either overkill or require server side CGI's to accomplish
their function.
sample calendars can be seen at http://homepage.mac.com/eddiealbert/
REQUIREMENTS
Macintosh system 9.0
Applescript 1.1
Basic knowledge of HTML
