Download: http://archive.info-mac.org/inet/html/unisite-104.hqx
Unisite allows you to write html files in any language on the Internet and
create multilingual web sites easily.
Unisite has full Unicode support and a built in professional HTML editor.
You can create web documents even in languages previously unavailable on the
internet.
*Automatic language selection.
You do not have to do any language formatting. Simply drag and drop text
into the Unisite window and the html file will be multilingual.
If any single language is used, Unisite will automatically select the most
appropriate encoding.
*Multilingual Find feature.
More powerful than all other high-end word processors or editors; you can
find text in any language with Unisite.
*Text Clip is available as a Template to easily handle sets of html Tags.
Of course Multiple languages are available in Text Clip.
*Numerous Unicode editing functions. Compulsory Unicode conversion, Unicode
paste, language conversion etc.
*Web Browser Preview. You can preview your documents in a Web browser with a
single click.
System requirements
Hardware Power Macintosh, with more than 2 MB memory
OS version and others MacOS 8.0 or later, Text Encoding Converter
1.31 or later (1.5 is recommended.)
Internet Control panel (or Internet Config 1.4 or later)
For multilingual use Language Kits from Apple Computer or a localized
system.
(Mac OS 9.0 includes all Language Kits previously available as separate
products as an optional install).
MAKI Enterprise Inc.
