simpleHype
simpleHype
Download: http://archive.info-mac.org/inet/html/s ... ype-12.hqx
simpleHype creates basic hypertext documents. It requires no HTML, nor
does it generate HTML. Instead it creates self contained hyper text
documents that have links that open windows when you click on underlined
text. It works VERY simply. If you want to add a link just select the
text for the link and pick make link from the appropriate menu. You then
get a window to type your text in. That's pretty much it!
