Download: http://archive.info-mac.org/inet/html/s ... ks-131.hqx
Web publishing with the notepad ScribblingWorks 1.3.1
This program, written in Smalltalk, is a notepad application. The users
get a few functions to managing notes. Each note has an own scrapbook.
With the "Quick Web-Side Wizard" you can create a complete web side of
the database contents with a few mouse clicks. So you can publish text
informations like news, infos, FAQs or recipes to the WWW. It is possible
to sort the notes by topics. The notes can marked with symbols. Links
between notes can set by the user or create automatically by the
application. A lot of navigation functions and a fuzzy search, helps to
find a note.
ScribblingWorks is Shareware and cost 20US$.
Requirements
- MacOS 7.5
- 8.3 MB Ram
- 7 MB on harddisk
