Screwy HTML Fixer 1.5
Download: http://archive.info-mac.org/inet/html/s ... xer-15.hqx
Screwy HTML Fixer 1.5 - ($5) If you have PageMill, you need this program. Adobe PageMill is great, but it will add funny junk to your HTML code. PageMill adds height tags to tables and cells, but gives you no good way to delete them. It adds NatrualSizeFlags to all your images. It even claims the hard work of creating your page with a Meta tag, even if you do most the work in BBedit. No more! Screwy HTML
fixer tightens up those loose tables and kills stupid code. It even allows you to preview each change as it is made in your browser of choice. If you use PageMill, your going to love this program.
