Rename! v1.00 - rename files, fix HTML links
Download: http://archive.info-mac.org/inet/html/rename-10.hqx
Rename!(TM) eliminates the problems normally encountered when
moving files between DOS/Windows, Macintosh, and UNIX file
systems. By changing file names (case, length, and invalid characters)
and fixing links in HTML code, Rename! ensures that your Web pages
will work on any operating system. Using Rename! before you transfer
files (for example, uploading a Web site to a UNIX server) saves you
from needing to repair mangled filenames, broken links, and extra or
missing carriage return characters in text files. Run it every time you
need to update your Web site and never have another broken link!
System requirements:
* Power Macintosh or 68020 or higher processor
* 16MB RAM
* 5MB free disk space
* System 7 (7.5 reccomended)
For more information, please see the visit this site:
http://www.visiontec.com/rename
Thank you,
Terry Parker (the author)
Parker & Associates
