JChecker 2.1
JChecker 2.1
Download: http://archive.info-mac.org/inet/html/jchecker-21.hqx
HTML Validation & Link Checker
JChecker2.1 Rev.2.1.1
JChecker checks lost links, hierarchical relations of elements, end tag
matching, tag ordering, spellings of tags and attributes, and so on.
You can correct these detected errors immediately with a powerful built-in
editor.
You can write HTML without concern to minor rules or mistakes. JChecker will
do the checking for you.
Also it supports the beatifying of HTML which will make your HTML more
comprehensible and the minimization of HTML which will bring shorter loading
time and smaller saving space in your web server.
Hardware Requirement:
€ MacOS 8.0 or later
€ Power Macintosh
€ Needs vacant memory of more than 2MB.
Features:
€ Checks over fifty varieties of items such as lost links, hierarchical
relation of tags, corresponding ending tags, order of tags, types of
attribute values and spellings of elements and attributes based on the "Tag
Dictionary" and the "Attribute Dictionary."
€ Supports a built-in text editor. You can correct errors immediately
with this powerful editor which supports HTML coloring, line number display,
search and replace, drag and drop, Internet Config and multiple-Undo.
€ Supports beautifying HTML texts. Options such as indents corresponding to
tag hierarchy, or the deletion of line feed codes may be specified.
Beautifying options for each tag can be specified in Tag Dictionary.
€ Supports minimizing HTML texts. It may reduce the size of HTML texts by
stripping needless spaces, tabs, line breaks.
€ Supports 28 character code sets such as Western, Japanese, Chinese,
Korean, Cyrillic, UTF-7, UTF-8 and so on.
€ The "Tag Dictionary" and the "Attribute Dictionary" may be customized.
User defined tags and attributes may be added later.
€The validity of elements and attributes will be checked for each version of
HTML specifications , Netscape Navigators and Internet Explorers.
€Both remote and local links will be checked in the link checking,
€ By linking function to Netscape Navigator or Internet Explorer, HTML texts
may be checked and modified while browsing in web browser.
€ Compatible with Word Service protocols. JChecker can check the HTML
documents in other applications which are compatible with Word Service such
as Jedit3.0 or BBEdit.
€ Supports Apple Script. You can open, check, beautify, minimize and save
HTML texts in Apple Script.
For more information, please read the text files enclosed, or visit our Web
page:
http://www02.matsumoto.co.jp/product/jc ... dex_E.html
Satoshi Matsumoto
Matsumoto & Co.,Ltd.
http://www.matsumoto.co.jp/
