HTML Cleaner
HTML Cleaner
Download: http://archive.info-mac.org/inet/html/html-cleaner.hqx
HTML Cleaner is an AppleScript for BBEdit 5.0 designed to perform a few
common HTML chores:
€ Based on the presence of a frameset in your document the script will
identify your page either as HTML 4.0 Transitional or HTML 4.0 Frameset.
€ It adds an empty alt="" attribute to image tags that don't have an alt
attribute already.
€ It gets rid of heights, since they are not permitted in HTML 4.0
Transitional.
€ It will by default get rid of heights, since they are not
permitted in HTML 4.0 Transitional. MSIE still uses them, though. There
is a preference setting, should you choose to keep table heights.
€ It will remove a stray "frame" attribute in a table, when no value is
specified for it.
€ HTML Cleaner will discontinue the existence of gridx, showgridx,
usegridx, gridy, showgridy, usegridy in your tables.
€ It will attempt to place your noframes tags inside your frameset,
which is where they should be.
€ The script will take (illegal) spacer tags and replace them with a
dot.gif image. it's up to you to make sure there are dot.gif images in
the referenced places.
€ It will remove xpos attributes in a tag.
€ In BBEdit 5.0, the script will run the CyberCleaner tool, which gets
rid of (some) excess font tags.
CAUTION! This script works fine for me, but may need some adjustments
for your specific HTML. Please test thoroughly on a COPY of your site.
