Download: http://archive.info-mac.org/inet/html/frame-easy.hqx
"Frame Easy" is a small application for Macintosh computers, enables you
to learn the art of frames step by step in a very easy way .
If you follow steps accordingly, we guarantee that you will master the art
of frames, ranging from developing simple frame sites to very complex frame
sites in hours.
"Frame Easy" also explains how to update two or more frame windows at once
along with some new tips.
Topics:
______________
- Introduction
- Syntax
- Targeting
- Understanding
- Exercises
Exercises 1
Exercises 2
Exercises 3
Exercises 4
html pages for each exercise have been provided online for
your practice. You can check "Exercises" directly from within "Frame Easy"
apllication.
- Advance
System Requirement: System 7.5 or higher. In order to check exercises
online, "Finder Scripting Extension" which comes along with system 7.5 or
higher and other regular Apple script extensions must be installed on your
system.
