Download: http://archive.info-mac.org/inet/html/f ... ww-102.hqx
FormDrop WWW v1.0.2 (This update should replace FormDrop WWW v1.0)
FormDrop WWW v1.0.2 Fixes a bug which caused FormDrop to not
implement drag-and-drop on some macs.
On The World Wide Web, forms can be used to send information when
one is at a web site. If you have a web page which uses forms, when people
visit your site and use the forms, the data is sent to you as an e-mail
attachment. This file, if opened in a text editor will look like one long
line of garbled letters, numbers, and words.
FormDrop WWW is a simple drag-and-drop utility to translate the
output files of forms from the Web into readable text documents that can be
opened with SimpleText.
To Use:
Drag and drop any World Wide Web form output text file onto
FormDrop WWW. The program will create a decoded file with "(Decoded)"
appended to its name. You may also drop multiple form files onto FormDrop
WWW and it will decode all of them.
Visit me on the web at:
http://www.lclark.edu/~jscott
