PPPfloater 1.2
PPPfloater 1.2
Post by Info-Mac » May 31st, 1995, 9:00 am
Download: http://archive.info-mac.org/inet/conn/p ... ter-12.hqx
©1995 by Hiroshi Lockheimer
NEW FEATURES:
Configureable via PPPfloater's Control Panel
Cumulative Timer function
Hot-key to open a PPP connection
...and many bug fixes
PPPfloater is a Control Panel that will automatically open a floating
windoid whenever you open a MacPPP connection. The PPPfloater windoid
"floats" above all other applications for easy access.
The floater has two functions: it will provide you with a "scissors" button
that will close the connection, and it will also display the amount of time
you have been online. Click anywhere inside the window (except for the
title bar and scissors, of course) to temporarily toggle the display to the
cumulative timer.
PPPfloater allows you to optionally set a "hot-key" that will open a PPP
connection. This feature is useful for those who Hard Close their PPP
connections: Config PPP no more.
PPPfloater is FREEWARE
