OT/PPP Switch 1.5.1
OT/PPP Switch 1.5.1
Download: http://archive.info-mac.org/inet/conn/p ... ch-151.hqx
This is the newest release of OT/PPP Switch, an AppleScript application
that toggles the state of your PPP connection. If you are connected, it
will close the connection. If you are not connected, it will attempt to
establish a PPP connection using the current settings in the PPP Control
Panel.
New Features:
*You can escape from a connection attempt by hitting the cancel button,
and the app will ask if you want to retry or quit.
*If the connection attempt fails, the app will ask you if you want to
quit or retry.
*All error messages should be trapped and dealt with without the user
seeing them.
System requirements:
*Any system with AppleScript and Open Transport/PPP installed (including
the standard scripting additions and the PPP Commands scripting addition
that is installed with OT/PPP).
For more information, and the latest updates, check my renovated web site
at http://www.inch.com/~tjb/adoor.html
Tom
