OT/PPP CSM 1.3a
OT/PPP CSM 1.3a
Download: http://archive.info-mac.org/inet/conn/p ... sm-13a.hqx
ot-ppp-csm-1.3a - This control strip module is for use with Open
Transport/PPP or ARA 3.0 and allows you to connect and disconnect to an
PPP Server. You must have installed and configured OpenTransport 1.1.1
or greater and OT/PPP 1.0 or 1.01 and the Control Strip 1.3 or greater.
You can also use ARA 3.0 instead of OT/PPP It is better that you don't
check the "Load only when needed" option in 'TCP/IP', because 'OT/PPP
CSM' needs TCP/IP to be loaded. If you check the option TCP/IP will be
loaded during the startup process of 'OT/PPP CSM' and the option doesn't
make sense. 'OT/PPP CSM' has been successfully testet on Macs and
PowerMacs with the these Systems: System 7.5.3 to 7.6.1 using OT/PPP 1.0
and OT 1.1.1/1.1.2 System 8.0 using OT/PPP 1.0.1 and OT 1.2, System 8.0
using ARA 3.0b16 and OT 1.2
