Download: http://archive.info-mac.org/inet/conn/p ... bot-16.hqx
This is the newest release of OT/PPP Bot, an AppleScript application that
stays open and runs in the background to maintain a PPP connection using
OT/PPP. With this version, I have tried to make the Bot operation fool
proof--you should see no operational errors if you cancel out of
connection attempts, you can set preferences for just about any aspect of
what the Bot does, and it should aggressively check and maintain your
connection.
New Features:
*You can escape from a connection attempt by hitting the cancel button,
and the Bot will ask if you want to retry or quit.
*You can set the idle time period to one of three possible settings.
*If you use multiple accounts, simply enter the information for the
account you want to use the Bot with, and it will connect to that account.
*Easily change user preferences by launching the Bot while pressing the
option key.
System requirements:
*Any system with AppleScript and Open Transport/PPP installed (including
the standard scripting additions and the PPP Commands scripting addition
that is installed with OT/PPP).
*Jon's Commands, a free scripting addition available from Info-Mac in the
Development/OpenScripting directory.
For more information, and the latest updates, check my renovated web site
at http://www.inch.com/~tjb/adoor.html
Tom
