Netcom/TIA/PPP Installer 1.0
Download: http://archive.info-mac.org/inet/conn/p ... ler-10.hqx
This installer installs TIA, PPP, and the PPP and MacTCP settings you need
to turn your Netcom shell account into a pseudo-PPP account.
The Netcom/SLiRP/PPP and Netcom/TIA/PPP installers turn a Netcom shell
account into a pseudo-PPP account, so that you can use TCP/IP programs such
as Anarchie, Eudora, Fetch, MacMUSH, Netscape, NCSA Telnet, and Newswatcher
(or YA-Newswatcher). This doesn't increase the fees that you pay to Netcom.
The installers install PPP, and the PPP and MacTCP settings you will need
to set up Netcom and PPP. The installers also automatically install either
SLiRP or TIA into your regular personal dial-up account on Netcom, and PPP
on your Macintosh. No Unix commands need be entered by you nor do you have
you access your shell account at all, all the work is done by the
installers. Installation in your user directory takes less than 100 bytes.
The installers also detail the specific step-by-step instructions for
configuring PPP and TCP/IP programs for your user id and modem. Netcom does
not support SLiRP or TIA and will not answer any questions about it, but
allows its use.
