MacSLIP scripts
MacSLIP scripts
Download: http://archive.info-mac.org/inet/conn/p ... mer-20.hqx
It is a utility application to be used with MacPPP that allows you to
keep track of how much time you spend on your PPP account. MacPPP must
be installed on your computer for it to work. MacPPP Timer requires
System 7.0 or later. Please post it to comm/tcp/conn/ppp/ and remove
all previous versions.
Version 2.0 adds support for OT/PPP, FreePPP 2.6 or greater and allows
automatic opening of internet browser or other application when MacPPP
Timer is launched.
Thank you,
Eric Preston
Here are two MacSLIP scripts that I modified from the sample.script that
comes with MacSLIP. I have used the Netcom script (mac-slip-netcom..) for
some time now without any problems. And it is setup to start The Internet
Adapter (TIA) on a Netcom shell account. The UUNet script
(mac-slip-uunet..) is one I just modified to work on my UUNet PPP account.
So far it seems to work OK.
I hope these scripts help others get up on their accounts in less time than
it took me.
Frank E. Smith ([email protected] soon to be [email protected])
