Download: http://archive.info-mac.org/inet/conn/p ... -qk-40.hqx
The MacPPP QuicKeys are three QuicKeys extensions which communicate
between QuicKeys and PPP. They allow QuicKeys to open and close PPP and
test whether it is open or closed, doing a decision or jump on the outcome.
The MacPPP Quickeys need QuicKeys 3.0 or better and System 7.0 or better
and are fully compatible with MacOS 8.
They work with all versions of MacPPP, FreePPP and OT/PPP available at the
time of writing, including FreePPP 2.6, and are quite happy for you to
switch between them without restarting.
New in Version 2.0:
* Updated for compatibility with FreePPP 2.6 and OT/PPP.
* Auto-detects the relevant flavour of PPP, even if it is changed without
restarting.
* Fixed the bug whereby FreePPP 2.5 with MacTCP would only connect once.
The MacPPP Quickeys are shareware and costs $10 if you use it for more than
30 days.
