FreePPP Icon Update (Requires ResEdit)
Download: http://archive.info-mac.org/inet/conn/p ... update.hqx
What is it?
This is a quick set of resources to replace the icon resources in the
FreePPP 2.5 distribution. It requires ResEdit, which is available at
in the utilities directory.
I found the quality of the FreePPP small icon to be very ugly. So
these patches replace them with a more "styling" set wherever it
appears.
In the control strip, when you are connected, the phone will appear
with a cable attached, when you are disconnected, the phone cord will
not be shown. Sorry, its impossible at this time to do the same with
the System Menu.
This has not been made into a updater yet, due to the 3 or 4 different
releases of FreePPP 2.5, this distribution method assures 100%
compatibility with all 4 versions.
And as always, there's no promise it won't crash you, and I warranty
it for the amount you paid for it. Although theres no reason why it
should.
Lee Henderson
