Download: http://archive.info-mac.org/inet/conn/tcp-cc-11.hqx
TCP CC 1.1 replaces TCP CC 1.0.2 (nee TCP Switcher) which is on the
mirrors. OT/PPP CC 1.1 and Modem CC 1.1 are brand new.
This simple control strip module is for use with Open Transport and allows
one to change between TCP/IP configurations without going through the
control panel. If you have more than one way to connect to the Internet
with your Mac (like PPP and Ethernet), you should make configurations for
each method and switch between configurations instead of changing the
setting in the default configuration. In order to use TCP Configuration
Changer (TCP CC) to make changing configurations easy, first set up the
configurations you would like to use through TCP/IP. Use the Configurations
option under the File menu in TCP/IP to set up each configuration. This
module will recognize them immediately. The handy Open... feature allows
one to open TCP/IP from the module if changes are desired to the
configuration.
TCP Configuration Changer is buckware. If you like the product, send me a
buck. I think that there is room for a new form of software consisting of
small utilities such as this that would go under the category "buckware".
Pay a buck, add a nifty gadget that makes life a little easier.
TCP CC requires Open Transport.
