OTConfigs - AppleScript addition to configure OT
Download: http://archive.info-mac.org/inet/conn/ot-configs-as.hqx
- OTConfigs is an AppleScript scripting addition.
- It allows you to switch configurations of OpenTransport without having
to open the Control Panels, such as TCP/IP, and PPP.
For instance, if you have a configration "HyperNet" defined in your
TCP/IP control panel, you can write a script like this:
change config of OT_TCP to "HyperNet"
When you execute the above script, TCP/IP configuration gets changed
to the one named "HyperNet".
- The package contains sample AppleScripts, so you can start using it by
just entering the names of configurations you defined in your
OpenTransport Control Panels.
- Very useful if you are a client of mulptiple PPP connections because
you can change TCP/IP and PPP configurations, and then start initiating
a PPP connection by just one action.
- $10 shareware. (payable online)
Changes from the last version:
No code change. Mior changes in ReadMe files.
System requirements:
- AppleScript
- OpenTransport
Kurita Yosuke
