Download: http://archive.info-mac.org/inet/conn/i ... er-101.hqx
InterSLIPRedialScript2 is a dialing script (CCL) for InterSLIP. It is far
better than the built-in script in that it works better with all modems,
displays status and error messages, hangs up properly, and redials when
busy. Version 2 adds a quick disconnect and changes the format to
SimpleText. Open the script to view the documentation and script comments.
Put in System Folder:Preferences:InterSLIP Folder:Dialing Scripts.
!Redial 2.0 © 1994-1995 Snap Systems, [email protected], on 95-07-29
!this may be freely distributed as long as copyright message not modified
!redial is a dialing script for InterSLIP written by Mark Hickenbottom
!InterSLIPRedialScript2 is a dialing script (CCL) for InterSLIP. It is far better than the built-in script in that it works better with all modems, displays status and error messages, hangs up properly, and redials when busy. Version 2 adds a quick disconnect and changes the format to SimpleText. Open the script to view the documentation and script comments. Put in System Folder:Preferences:InterSLIP Folder:Dialing Scripts.
!put in System Folder:Preferences:InterSLIP Folder:Dialing Scripts
!tip for bad modems in modem banks:
!if you hear a bad modem connection,
