Download: http://archive.info-mac.org/inet/url-clerk-12.hqx
URL Clerk is a URL launcher. The URLs are stored in files, so you have all
the flexibility of the Finder at your disposal. URL files can be placed on
the desktop, in the Apple Menu, or anywhere that's convenient for you. URL
Clerk can also open up bookmarks created by Aladdin's CyberFinder or URLs
stored in clipping files. To find out more about URL Clerk's features, use
the provided balloon help. You should have no trouble creating and managing
your URLs with URL Clerk's simple and uncluttered interface.
New in URL Clerk 1.2 is a find function which allows you to search for a
URL based on its contents or URL type. Version 1.2 also incorporates a
number of bug fixes and features better memory management. Also included
with this archive are two QuicKey macros which makes it even easier to
create or launch URLs, and the Bookmarker application to facilitate the
conversion of text and clipping files to URL Clerk bookmarks.
This program requires Internet Config 1.1 or later, which is available at
. System 7.1 or later is
also required. URL Clerk is both 68k and PPC native.
URL Clerk is freeware.
-Jeffrey Posnick
[email protected]
