Download: http://archive.info-mac.org/inet/rmore-url-102.hqx
RmoreUrl-1.0.2 is a free opensource Macintosh MRJ based server/UNIX C
commandline client combo whose only purpose is to pass URLs from a
UNIX/Linux box to Internet Config (and thus to your Mac based browser,
ftp client, email client, etc.).
Instructions for configuring emacs VM and emacs Gnus to allow a single
UNIX URL click to cause you Mac to access the same URL may be found at
This is probably only useful for you if you frequently run MacOS and
UNIX behind a firewall/NAT server, you frequently want to view/use
URLs from your mac which are located on your UNIX box, or you have
access to both OS's displays at your work area.
Source code is available from .
WARNING
Do not use the RmoreUrlServer program on a Macintosh directly
reachable from the internet (not behind a firewall or NAT server). The
simple protocol used the the RmoreUrlServer is not safe to internet
connected machines not behind a firewall. It would be easy for an
attacker to download files or send you browser to any webpage if you
are not protected. This means your Macintosh should behind a firewall
and the port you specify in your RmoreUrlServer should be
protected/filtered. If you don't know what this means ask someone at
your site/ISP.
--Rod Morehead
[email protected]
