Download: http://archive.info-mac.org/inet/retrieve-im-101-as.hqx
This AppleScript was written to facilitate interaction between EasyView and
Anarchie. When an EasyView clipping file from the Info-Mac Digest is
dropped onto the applet, it will download all the files mentioned.
Basically, the script searches the clipping files for the filenames at the
end of each entry in the digest. It then sends each to Anarchie, which
automatically expands the reference into a pathname at the Info-Mac mirror
selected in the preferences.
This script is copylefted, and may be distributed on the Info-Mac CD.
Changes:
v1.0.1 Bug fix -- stopped the script from opening Scriptable Text Editor
before downloading the files. This was left over from debugging.
Brad Ackerman
[email protected]
