Monolith DYNDNS Register
Download: http://archive.info-mac.org/inet/monoli ... gister.hqx
Made in REALbasic, Monolith DYNDNS Register will prompt you with a dialog
box the first time you open it asking for your host name, your MID, and
your password. The next time you open it, it will automatically connect
to monolith, submit the proper information via the http protocol, and
quit two seconds after it is done with the registration process if the
host was successfully updated. If the host name has already been updated
within the last five minutes or updated with the same IP address, then it
will display a status message indicating such as event has occurred and
will not quit automatically. If for some unknown reason it was
unsuccessful in the registration process, it will display in the status
area, "Host NOT successfully updated." You also have the option to
change your host, mid, and password information after you have initially
provided it. The preferences are stored in a file by the name of
"Monolith Registration Prefs" inside the Preferences folder on the
current startup disk.
