Download: http://archive.info-mac.org/inet/key-holder.hqx
This file may be included on the Info-Mac CD-ROM archives.
Key Holder 1.0
© Copyright 2001 System Support Products, Inc.
Written by Lou Forlini
Key Holder gives you quick and easy access to your online account
login information!
Key Holder is a password account database application. For each
account, the account name, user, password, Internet URL, and a memo
field for miscellaneous notes can be kept. A menu command allows you
to go directly to the account URL by automatically launching your web
browser, e-mail, or other Internet application.
Key Holder supports multiple account files. Account files are
encrypted and can be individually password protected, allowing one or
more users to maintain private and secure account lists. A find
command is available for searching, and account files can be printed
for offline storage.
Key Holder can also be used to keep a list of software registration
codes, by entering the registered name into the user field and the
registration code into the password field.
SYSTEM REQUIREMENTS
Key Holder requires an Apple Macintosh or compatible with a PowerPC,
68020 or greater processor, using Mac OS 7.5 or later.
