IP Poster Script version 1.1 update
Download: http://archive.info-mac.org/inet/ip-poster-11.hqx
Since there is no Mac IP Poster application availible yet I decided to
write a simple AppleScript that uses Fetch 3.0.3 and IP Moniter 1.1.1 to
update a remote web page with your current IP address.
Requirements:
You must have System 8, Fetch 3.0.3 and AppleScript 1.1.2 or later
installed on your Macintosh to make use of this script. The script
makes use of the following Scripting Additions from Apple: Display
Dialog and Read/Write Commands. I am not sure if these Scripting
Additions are included in earlier releases. Try it and let me know.
http://hyperarchive.lcs.mit.edu/HyperAr ... or-111.hqx
http://hyperarchive.lcs.mit.edu/HyperAr ... ch-303.hqx
