ICFileDiverter 1.2.4
Download: http://archive.info-mac.org/inet/ic-fil ... er-124.hqx
Attached please find the latest version of ICFileDiverter. Use this
application to open documents based on the filename extension and the
corresponding application in Internet Config. For example, if you edit
your HTML files in BBEdit, so their Mac file type is TEXT and creator is
R*ch and the Finder opens them in BBEdit but the post-processing application
for .html is set to be Netscape in Internet Config, it will be opened in Netscape after a drag on ICFileDiverter. Keep a copy or alias of ICFD
on your Desktop and you never need to dig through folders any more!
This version does not any new features but is updated for 8.5 (ie. I
added Nav Services to it).
Cheers,
Marc
