Holmes
Holmes
Download: http://archive.info-mac.org/inet/holmes-10v2.hqx
Holmes Search Central 1.0 November 4,1998
What is it?
In the spirit of Sherlock on MacOS 8.5, Holmes is an internet search
utility for the rest of us. It provides one central location to query
numerous internet search engines. The software is quick, compact, and
PPC native.
What are its requirements?
Holmes will run on a Mac II or higher under System 7 or higher. It
runs in 1 MB of ram. Holmes requires a web browser (not included) to do
its work. It also requires Internet Config to be installed and
configured. Internet Config 2.0 is included in this distribution package.
How does it work?
Operation of Holmes is simple. Enter some text to search for, select
your search engine, and hit the Search button. If the text you enter is
an internet url, just hit the URL button. Holmes has lots of balloon
help which should help you understand its operation.
Thank you for downloading Holmes. I hope you like it.
John
