Download: http://archive.info-mac.org/inet/forgot-it-121-68k.hqx
ForgotIt? 1.2.1 is a password and URL management tool that uses
strong Blowfish or RC4 encryption to protect your passwords. It can
launch URLs by a simple click, print out password lists and export
them in Base64 format or plain text. It is a classical user-friendly
multiple-document Macintosh application and comes with excessive
online help (also available as download). ForgotIt? does also support
3rd party encryption plugins.
ForgotIt? 1.2.1 is $15 shareware.
Author: Erich H Rast
Requirements: Macintosh PPC/68k (2 different program versions
available) OS 7.5 or higher (8 recommended), 2 MB RAM, Internet
Config
Version 1.2.1 fixes a bug that inadvertantly caused the previous
version to expire.
