Download Macros
Download Macros
Download: http://archive.info-mac.org/inet/download-macros.hqx
Download Macros are a set of macros that ease downloading files from the
Internet, and more. This software is freeware. Here's a description of
all the different macros:
DM: This will download batches of files (.sit, .hqx, .bin) in Netscape
2.x or 3.x.
DM Enforced: A version of DM that can download all file types, but does
not map it to it's corresponding helper application.
DM Enforced Sequential: A version of DM Enforced that downloads a series
of related files, which then renames them to whatever you want, followed
by a dot and the download number. For instance, header.1, header.2,
header.3.
DM Enforced Sequential Reverse: Same as the previous but the numbers go
backwards starting from a specified number.
MSIE Downloader: A Download Macro that will download any type of file
using Microsoft Internet Explorer versions 3.0.1 or 4.0p1, but does not
route it to it's corresponding helper application. This macro took me a
while to complete, as it required a completely different approach than
the Netscape versions.
Hotline DL: If you can't download from a Hotline site because the
maximum number of simultaneous downloads are taking place, this macro
will consistantly try for you until it works.
Hotline Resume DL: Same as previous, but for any file you want to
resume.
Delete Cache: Deletes the cache for Netscape, MSIE, and the America
Online web browser all at once.
Requires:
Netscape 2.x or 3.x, MSIE 3.0.1 or 4.0p1, Hotline 1.1b21 (respectively)
KeyQuencer 2.x
Jared Mellin
