Connect me to... freeware WWW Utlity for Macintosh
Download: http://archive.info-mac.org/inet/connect-me-to-10.hqx
I must admit that the "Connect to..." script which comes with the MacOs is a
pretty good little utility by Apple Computer, Inc.
However, I have often been frustrated by not being able to change the
default URL that comes with it, and not being able to have a list of
favorite URL's which I can access from my desktop. That's why I put together
this little freeware application. It is meant as a replacement for the
"Connect to..." script, and I believe you will find it very versatile and
easy to use.
To start off, you must have:
A PowerPC computer
MacOS 8.5 or later
AppleScript
A web browser
If you would like to place this application in the Apple Menu, where it was
designed to go, simply double click on the "Installer applet". All the
moving will be done for you instead of you having to dive into multiple
folders. You can either delete the "Connect to..." script or use this
program in addition to the default script that comes with the OS.
web page: http://home.earthlink.net/~aragorn2
email: [email protected]
