Download: http://archive.info-mac.org/info/sft/bb.hqx
Demo copy
Black & Bleu is an application that shows you the meaning of all of the documented and many of the undocumented Mac OS error codes. Many codes include information about what might be the cause of the error and what you can do about it.
The database contains over 2500 error codes with Apple's short explanations of each. Our detailed explanations and remedies are included for the most common of these errors. The type of detailed information can be selected from 2 categories: a Non-technical User orientation and a Programmer orientation. The Non-technical User explanation is presented in a way that someone without a programming background can understand. The Programmer explanation is written in VERY technical terms that usually includes source code that demonstrates the error. To fully understand the Programmer explanation, you should be familiar with Macintosh programming (in C or C++).
Black & Bleu is also available from our web site: www.bleurose.com as a free fully functioning demo. This demo can be launched for a total of 3 times before it expires.
