The attached file is an RTF file explaining how to save PowerBook battery
life. I wrote it for work, and felt that it would be useful for the wider
Mac community.
If the RTF format is a problem, I will post a different format.
Feel free to mail any suggestions, corrections, etc.
11-Apr-92 17:39:58-GMT,19154;000000000001
Received: from SUMEX-AIM.Stanford.EDU by CAMIS.Stanford.EDU (4.1/inc-1.0)
id AA04654; Sat, 11 Apr 92 10:39:57 PDT
Full-Name: Info-Mac Moderator
Received: by SUMEX-AIM.Stanford.EDU (4.1/inc-1.0)
id AA02770; Sat, 11 Apr 92 10:39:57 PDT
Resent-Message-Id:
Return-Path:
Received: from hila.hut.fi by CAMIS.Stanford.EDU (4.1/inc-1.0) id AA14698;
Sat, 11 Apr 92 02:50:31 PDT
Received: by hila.hut.fi (5.65c/7.0/S-TeKoLa) id AA21515; Sat, 11 Apr 1992
12:49:28 +0300
Message-Id:
To: [email protected]
Resent-To: [email protected]
Hi
This is a copy of the report I made about PowerBook LCD displays a week or two
back. Due to numerous requests, I have decided to submit it to you, for the
reports directory, or the digest or whatever is most apropriate. I have never
really done this before, so I hope all goes well.......
This is a more detailed description of how an LCD display works. I will not
go into detail about the difference between Active/Passive etc. This is
purely to explain the ScreenSaver effects and things.
For all Chemists out there, I realise this discussion isn't totally accurate
but it is 'correct' and I can't be bothered to give a lecture course on nematic
crystals!!
