Download: http://archive.info-mac.org/info/hdwr/m ... matrix.hqx
Enclosed is a complete matrix of Macintoshes and Displays (both past and
present and near future) and what color depth is available in differing
configurations.
This grew out of the need for such a reference in the Computer Resource
Center at Dartmouth College (the pre-sales demo area). We found Apple's
matrix from AppleLink to be both hard to read and also quite wrong (we just
tested various configurations against the May version of Apple's Matrix and
found the Apple Matrix sadly wrong in *many* places.)
We believe this chart to be error free, but reality being what it is we do
encourage anyone to contact us if you do find a mistake.
Comments, suggestions, errors, and more can be sent to [email protected].
The chart used Helvetica and AppleGaramond. (The latter only in the credit
line at the bottom so if you do not have this font, nothing should be really
affected).
Hope this helps!
-Andy J. Williams
Manager, Computer Resource Center, Dartmouth College
[email protected]
NOTE: The following Macintosh file(s) are enclosed with this
message, in BinHex format. If your mail system does not convert
BinHex files automatically, you will need to transfer the message to
a Mac and run the BinHex application to decode it.
Filename: CRC Monitor Matrix.sit Size: 6380 bytes
