apple-13in-monitor-fix-r2
Download: http://archive.info-mac.org/info/hdwr/P ... -remap.hqx
These files explain how to make the row of function keys on your
PowerBook (anything beyond the 100 series, unless I hear otherwise)
serve as PageUp, PageDown, Home, End, and Forward Delete.
You'll wonder how you ever did without them!
This version includes instructions which work with System 8.
Steve
http://lifesci.ucsb.edu/~haddock
Document : apple-13in-monitor-fix.txt
Revision : 2
Date : 31 Jan 1995
composer : [email protected]
CHANG, Kui Yu (Julian)
1 MONITOR
AppleColor 13" High-Resolution RGB monitor
2 PROBLEM
Powers itself off sporadically, green power light goes off with switch still
stuck at 'ON' position.
3 SOLUTION 1
