The Musician 3.1.0; sound utility.
Download: http://archive.info-mac.org/gst/snd/the ... pro-31.hqx
The Musician 3.1.0; soundutility.The Musician Pro plays any sound
fileQuickTime supports directly ('Mp3 ', 'MPG3', 'PLAY', 'SwaT',
'WAVE','AIFF', 'AIFC', 'VfW ', '.WAV', 'Midi', 'ULAW', 'sfil',
'BINA','MPEG', 'MPGa', 'MPGv', 'MPGx', 'dvc!', 'sd2f', 'MooV' and
more...)and, if you want, files supported through conversion (i.e. CD
Audiotracks ('trak')). Moreover The Musician Pro plays 'snd '
resourcesinside whatever file! But the strength of The Musician Pro is
its scanning ability: it mayexplore your HDs, CDs, folders, diskettes,
files, searching forsounds to play. For example you may drag your disks
on The MusicianPro then continuing your normal work: The Musician Pro
will play,asynchronously and in background, any file of above that
willfind. According to your setting The Musician Pro can play any
soundimmediately or after your consent, in addition you may instruct
TheMusician Pro to collect aliases of sound files, while it's playing,so
you may enjoy them, when you want, without perform anothersearch. The
main window has a simple bar that meters the input level of
themicrophone, you may disable the bar through the preferences. At last
The Musician Pro may show the QuickTime keyboard (for yourfun!) and
record new sounds in 'sfil' or 'AIFF' format. After all you may use the
enclosed Contextual Menu Extension forasking The Musician Pro to play
your selection.
The Musician Pro is Internet Config, Drag Manager and NavigationManager
aware, moreover it's Appearance savvy. It requires at least aPowerMac
and System 9 to run and uses QuickTime to play almost allfiles.
What's new in 3.1.0 version
-Contextual Menu extension.
-Support of any sound file QuickTime sports.
-New About box.
-Minor bug, saving window position, fixed.
-Position saving for each window.
-Recompiled by using the newest compiler.
-Linked with MoreFiles 1.5.
-Recompiled with Interfaces-Libraries 3.3.
-Linked with Internet Config 2.0.2.
-Better Navigation Dialogs.
-Removed multiple streams.
-A bug in Navigation routines fixed.
-Try QuickTime on unknown files.
-Just one single window.
-Volume changing.
-Addresses update.
-68K processors no longer supported.
-Pro version.
