Sound Shuffler 2.0
Sound Shuffler 2.0
Download: http://archive.info-mac.org/gst/snd/sou ... ler-20.hqx
Requirements
Any Mac running Mac OS 7.1 or higher. This program is Mac OS 8.0, 8.6, and
9.0 savvy!
What is Sound Shuffler?
Sound Shuffler is a control panel that randomizes the Mac system alert beep.
It also plays sounds in a 'Sounds' folder located in the System Folder. Just
drop sounds in this folder and Sound Shuffler immediately takes advantage of
them. Sound Shuffler plays all sounds asynchronously, which means they will
play without hogging the processor. This allows you to continue to work
while your sound is playing. Any sound can be stopped by pressing the 'Esc'
key.
Sound Shuffler even lets you play sounds at random times, using the random
sound slider in the control panel. You can set the length of the delay that
Sounds Shuffler awaits.
Freeware
This program is freeware, which means that you can use it at no cost. You
may also pass it around freely as long as you include this read me and the
help documents.
If you like the program, feel free to drop me an email so I know that it
really is worth continuing.
Nick D'Amato
http://www.goddfaddasoft.com/
