Download: http://archive.info-mac.org/gst/snd/hyp ... ard-55.hqx
HyperKeyboard 5.5
What it is: HyperCard Melody Scripting Tool
Author: Ton Brand
Company: Ton's Software
License: Shareware US$6
Computer: Any Mac
Mac OS: 7.0 or later
Required: HyperCard Player 2.2 or later
Abstract:
HyperKeyboard is a HyperCard Melody Scripting Tool that should reside in
your HyperCard folder. It enables you to make compositions and process them
any way you like: Compress or convert a melody line, replace the sound or
even modify key, octave and duration. Put finalized compositions into a play
list. Edit them afterwards or install them onto another HyperCard stack.
Buttons are grouped in functional clusters; most of them can be
shift-clicked for direct access to the relevant Help section which is in
English as well as in Dutch. Two special facilities, 'Auto Compression' and
'Test Import of Sound Resources', make HyperKeyboard stand out against other
melody scripting tools. HyperKeyboard is shareware. Version 5.5 fixes an
error - there was a black key missing - with the musical keyboard.
