Gammasoft NoteMaker
Gammasoft NoteMaker
Download: http://archive.info-mac.org/gst/snd/gs-notemaker.hqx
This program lets you make music. This uses the HyperCard play command.
Very little support is included for polyphonics, and even this support
doesn't work. Song samples are included.
This file requires the Gammasoft Runtime Engine. If you don't have the
Gammasoft Runtime Engine, you can download it from this server or, if you
have MacOS Easy Open enabled, use the HyperCard Player instead.
When you decompress this folder, be sure to put it in the same folder as
the Main Menu file. Also put an alias of the NoteMaker file in the `Data
folder. Make sure the alias doesn't have an " alias" suffix or a space
after it's name.
