d-soundpro-351
d-soundpro-351
Download: http://archive.info-mac.org/gst/snd/d-soundpro-351.hqx
D-SoundPRO 3.5.1
COPYRIGHT © 1998 - Stefano Daino
All rights reserved
D-SoundPRO is a professional Audio Sound Editor, Software Synthesizer, Wave
Generator and samplers MIDI/SCSI network manager. Its features are:
- Load/Save AIFF, SDII and .WAV mono/stereo 8/16 bits sound files up to 48
kHz
- Akai, E-MU, Kurzweil, Roland, SMDI, Yamaha SCSI sample dump supports
- MIDI SAMPLE DUMP STANDARD (also with Yamaha SY sample headers) and S50,
S550, S330 MIDI supports
- Virtual Synthesizer module, to play samples from the Mac Keyboard or from
MIDI (also from a sequencer running on the same Mac), including a real time
AmpENV ADSR module.
- Midi Notes, Pitch Bender, Sustain Pedal real time midi messages support to
play the Virtual Synthesizer
- Import/Export sounds from 3 1/2 Roland® Samplers Disks (W30, S50, S550,
S330)
- Import/Export sounds in RAW format
- Sophisticated and undoable sample edit & clipboard management with Redo
function
- Floating palettes for edit tools, loops monitoring, sample info, and
Virtual Keyboard.
- X-Fade looping algorithm with programmable window length & X-fade
coefficient
- Time Stretching (with old/new BPM tempo input parameters) and Frequency
Shifting parametric algorithms by a Spectral Resynthesizer
- DSP Mono, Stereo, MultiTap Delay, Stereo Chorus, Early Reflection
Reverbers and Stereoizer effects
- LowPass, BandPass, HighPass and BandReject analog filter simulation with
feedback up to self resonance (-12, -24, -36, -48 dB/oct selectable curves)
- Full Parametric (Freq, Q, Gain) three ways and 7 Bands Graphic Equalizers
(+/- 18dB)
- Rhythm loop for fast auto looping of musical audio files
- Detect BPM function, to know which is the tempo from an audio file
- HQ Digital Oscillator functions to generate new synthesized sound waves
(up to 10 detunable SW oscillators at the same time!)
- Resample using interpolation
- Pitch conversion
- Normalization
- Complex sample extraction functions
- Zooms and visual tools
- Full OMS 1.2 (or better) optional support
- It is a FAT application - it runs native on PowerMac
- Japanese and Italian versions available (German and French very soon)
- User Manual included
System requirements: System 7.1, SoundManager 3.1 and a 68020 MAC
supporting 16 bit audio (68030 mac recommended for MIDI and PowerMac for
full performaces).
Optional: MIDI interface and synth supporting MIDI Sample Dump Standard, a
MAC with sound inputs, OMS 1.2 (or better), FreeMidi 1.34 (or better).
D-SoundPRO is a program which is distributed as SHAREWARE. This version is
fully operating. You are permitted to use it on a trial basis for up to 15
days. If you wish to continue using this product beyond that period, you are
expected to pay a registration fee of $39 (the update fee for version 2.x
registered users is $10).
You will receive a registration code which you may enter to eliminate
registration screens. Thank you for your help to this shareware product.
You can distribute an unregistered copy of D-SoundPRO 3.5.1 on commercial
CD-ROM if you include also all files you find in archive as they are. You
are kindly request to send me a free copy of your CD-ROM.
This is the official D-SoundPRO home page:
http://www.d-soundpro.com
Here you will always find the last release of D-SoundPRO, info, the user
manual on line, links for downloading and more.
This is my email for informations, help and bugs report:
Stefano Daino
