ConvertMachine 1.0.2v1J - Japanese Version
Download: http://archive.info-mac.org/gst/snd/conmach-121-jp.hqx
This is the Japanese version of the ConvertMachine package.
ConvertMachine is a batch processing utility to convert sound format
files to a desired type. This means it performs one or more of the
following without user interaction: decompression, resampling (sample
rate conversion), mixing (stereo to mono) and compression.
You don't need to worry about what format the file is in; all you
specify is the desired output format.
Finder Sound files (sfil), AIFF files, WAVE files, AU Mu-law and linear,
QuickTime Audio (Movies) and Sound Designer II files can be freely converted.
You can save your popular Settings under as a menu item or as a separate
Settings file. The common web formats are flagged and ready to use as
defaults, such as audio/basic mono 8kHz mu-law.
After conversion files can be automatically sent to SoundMachine for playing.
It needs at least QuickTime 2.1 and Apple's Sound Manager 3.1 or later.
If you have installed System 7.5.3 then, no worries, you have these. If
you want to get these or later extensions visit Apple's web site.
Changes in version 1.2
*Added an Import/Export... item under the File menu which permits
importing of Audio CD tracks and the like (this feature was available in
1.0.6 but removed in 1.1).
*SoundDesigner II files with higher sample rates are now correctly exported.
