File for submission
File for submission
Download: http://archive.info-mac.org/gst/grf/pshp/photo-fits.hqx
Photo Fits
Photo Fits is an Adobe Photoshopx plug-in which allows import of FITS files.
Photo Fits can read byte, integer, longint, real, and double fits files.
Fits can not read fits files with extensions nor can it read 1D files. Photo
Fits only looks at the image or images pointed to by the first fits header.
Photo Fits can be freely distributed so long as it is not modified in any way
and
this read me file is distributed with Photo Fits.
I know that Photo Fits can not read all fits files and I am working on it.
Fits is not finished and if you find a fits file which doesn't work DO NOT
email
it to me, a short note will be good and a ftp site where I can download it.
Thanks for your understanding.
Hope you like it.
Doug Norton
Otter Solution
10 Limekiln Road
Whitesboro, NY 13492-2338
tel 315.768.3956
fax 315.736.4371
