Command_Transform1.0
Download: http://archive.info-mac.org/gst/grf/psh ... orm-10.hqx
Command Transform 1.0.0 is an Automation Plug-in for Photoshop 5.0
Command Transform 1.0.0 by Robinson Software web: http://users.abac.com/garyr
Command Transform is a Plug-in for Adobe Photoshop enabling the creation of
layered Photoshop documents using offsets, rotations, and scales from
images and picture boxes in Quark Xpress. With Command Transform you can
recreate the Exact placement of images in Photoshop 5.0 as well as crop
them to there Picture Box or use there path for cropping. The final procuct
of a Quark page using Command Transform is a layered Photoshop document
that matches the image position and crop of the Quark document. Command
transform also allows you to set the Resolution of the images in a way that
only requires one Transform to scale, rotate, offset,and change resolution.
Uses for Command Transform:
Desktop Publishing
Web development
System Requirements:
Macintosh
Power PC
System 7.5 or better
Photoshop 5.0 or better
Applescript enabled and its standard scripting additions.
