Photoshop clut converter
Download: http://archive.info-mac.org/gst/grf/psh ... verter.hqx
Hi,
Ever needed to convert a photoshop clut (color table) file into a clut
resource ? Here is a small application to do just that. It prompts for a
file to open, then prompts for a filename to save the new clut as. It saves
it's files as resedit documents. Simple as that. Source code is included.
Authors: Reevan McKay (clut conversion routine) and Mark Elliott (minimal
user interface).
There are a few planned improvements. Please do not distribute modified
versions of either the program or the source code. If you make a useful
modification, please send it to me, and I will incorporate it into the
distribution.
thanks
Mark Elliott ([email protected])
