CCallisto 1.1
CCallisto 1.1
Post by Info-Mac » June 13th, 1998, 9:00 am
Download: http://archive.info-mac.org/gst/grf/psh ... sto-11.hqx
CCallisto 1.1 - this Photoshop plug-in (PowerMac only) lets you create cool 3D TERRAINS from 2D artwork, all in Photoshop! You can also wrap your terrains around spheres to create PLANET objects. And, *all* objects you create in Callisto can be fully texture-mapped using PICT images. When you're done, save your 2D renderings into a new Photoshop window just by hitting OK. Or, save your 3D models as 3DMF files for later use in other 3D programs. This is a fantastic plug-in for getting some amazing 3D effects in Photoshop. The Save features are *enabled*, but to get output resolution greater than 320x240 pixels you'll need to register for $20. Callisto was written up in the May 4 '98 MacWEEK, p.13. It requires Quickdraw3D 1.5+ and Photoshop 3, 4, or 5. Extensive PDF documentation included.
