ThumbsUp 4.1
ThumbsUp 4.1
Download: http://archive.info-mac.org/gst/grf/thumbs-up-41.hqx
ThumbsUp is a simple, drag & drop based utility to create thumbnails or
icons for a bunch of pictures or movies and supports all image & movie
formats of Mac OS X and QuickTime (including PDF and PostScript
documents).
Thumbnails are either scaled by percentage or limited to a maximal size
and created as JPEG, TIFF, PNG, BMP or GIF files. In addition, it's
possible to specify antialiasing, sharpening and compression to
optimize the results. Finally, use ThumbsUp to convert PDF screenshots
easily to other image formats using drag & drop and scaling to 100%!
History:
- Possibility to drop folders onto ThumbsUp added
- ThumbsUp is more compatible to images with a wrong file extension or
HFS type
- Icons created from/for PDF/PS documents were sometimes transparent.
Fixed.
- Creating icons for existing images doesn't change the file
modification date anymore
- Some minor performance improvements
- Not all used memory was freed immediately while thumbnailing multiple
images
- More reliable "Check for updates" command
License:
Freeware
Author:
Christian Grunenberg, DEVONtechnologies
System Requirements:
Mac OS X 10.2 (or newer) and QuickTime 6.x
Info:
http://www.devon-technologies.com/produ ... eeware.php
http://www.devon-technologies.com/files ... /freeware/
Download: 200 KB, 204342 bytes
http://www.devon-technologies.com/downl ... reware.php
http://dl.filekicker.com/send/file/1545 ... sUp.dmg.gz
http://www.devon-technologies.com/files/ThumbsUp.dmg.gz
