Scrapit Pro 5.5
Scrapit Pro 5.5
Download: http://archive.info-mac.org/gst/grf/scrap-it-pro-55.hqx
Try the award winning utility called ScrapIt Pro (it has received many
awards and accolades from MacUser, MacWorld, MacAddict and many
electronic Mac publications)! Anything you can copy to the clipboard
can be pasted and stored in a ScrapIt Pro file. Features full support
of Apple's latest technology; Drag & Drop, QuickDraw 3D, Speech, and
more.
ScrapIt Pro, is the editable, searchable multimedia scrapbook... and a
mini-word and form processor to boot! Need a place to store, sort,
display and search all of your text files, forms (invoices, addresses,
contacts, etc.) , sounds, GIF files, JPEG files, QuickDraw 3D files and
more? Look no further, ScrapIt Pro is the utility you've been looking
for!
New features in version 5.5:
* Added PlugIns for selected text (such as stripping unwanted
characters, changing case, etc.)
* Password protected scrap files
* Can now store scrap files in folders within the ScrapIt Pro Folder and
have them accessible via the Scrap Files menu hierarchically
* Added Templates Scrap file support (gives you the ability to keep
often used pieces of text in one file for access from a popup menu in
any other scrap file)
* Can now search all open scrap files
* File comments are now kept when importing and exporting
* Movies can now be made to fill the scrap file window
* Print margins can now be set
* Can now specify any folder to be used as the Scrap File folder
* Total file size now displayed in tool bar
* Much nicer looking gallery view
* Option-Tab now used to change focus
* Command-Delete now used to delete selected items
