QXP PhotoBook 3.0.3
QXP PhotoBook 3.0.3
Download: http://archive.info-mac.org/gst/grf/qxp ... ok-303.hqx
QXP PhotoBook is a stand-alone utility which aids QuarkXPress users to
compile catalogs of images very quickly with a minimum of setup and user
interaction. Catalogs are saved as QuarkXPress documents, with an option to
then save as Acrobat PDF files. Some uses for QXP PhotoBook are printing out
thumbnails of images contained in a folder, or cataloguing a CD library of
images to QuarkXPress files.
QXP PhotoBook accepts any image format accepted by QuarkXPress including PDF
and GIF, as well as formats not supported by QuarkXPress, such as Adobe
Photoshop files, by choosing to import the PICT preview of images, or by
using third party XTensions. Users create catalogs by drag and dropping
files or folders onto PhotoBook's window or icon.
Many formatting options are provided, allowing users to choose page size,
colors, fonts, captions and headers and footers. The fully featured caption
option can - by using simple tags - automatically write a variety of
information about the image to the caption, such as the file's name, size or
dimensions, and more.
This versions corrects errors with captioning and importing of EXIF JPEGS
(digital files from cameras).
